VPS sample using Intel OpenVINO for face detection and classification
Attached you can find a sample for VPS that does face detection using Intel OpenVINO. It can detect and classify faces using the face-detection-adas-0001 and the age-gender-recognition-retail-0013 models. There is a README located in the gstvpsopenvinofaces folder that will give you more detailed information. Please note that the sample consists of two plugins: gstvpsopenvinofaces invokes the models, and gstvpsmetafromroi transforms the ROI metadata to ONVIF XML. The sample is tested to work with XProtect VMS 2020 R1.
Thank you for sharing this sample!
We want to run the video processing service and the video management system on the same device.
The IntelĀ® Deep Learning Streamer (https://github.com/opencv/gst-video-analytics) is only supported on Linux! So please do you have any idea on how to run this solution on Windows?
Thank you!
