We do not want to go via NTLM path. One of the documents available online states that we can use only windows credential for Corporate (https://www.milestonesys.com/contentassets/b65834ac39704f7c8837755c391efddf/acic_milestone_integration_1.4_en.pdf ). Please confirm
Basic users can be used. If doing protocol integration you must use SSL.
See -
and -
You are referring to a partner document, and this document accurately describes the solution partner’s integrations, for MIP SDK integration possibilities this might not be the best source of information. I hope you find my comments useful.
Thanks a lot. This was useful
