We have developed solution using two defferent versions of SDK
We have developed some functionality of Milestone recoredr integration using older version of SDK and remaining integration work we are doing using 2014 SP3 . Now the solution has developed using two versions of SDKs , is it OK, if not what is the possible solution and suggestion.
We reqest fo urgent response
Thank you so much for your support!
Karuna Prasad
Hello Karunaprasad,
Software development related questions should be directed to our SDK support team.
SDKsupport@milestone.dk
