Web Api Compression Hotfix for 25r1 and r2
Do we have an idea when this will be part of the full release or when the hotfix will be available that adds the web api compression for recording server communication.
I am sorry, but I do not understand what you are asking. I can’t say I have heard about neither a Web Api Compression issue nor hotfix. If there is an issue for which a hotfix is needed perhaps you could describe the issue.
Here is my milestone cases related to this issue when upgrading to 23r2: MSC1804694, and MSC1804062
For the past 6 or more releases, there has been a WebAPI Compression hotfix added for the recording server:
See release notes for the hotfixes below milestonedownload.blob.core.windows.net/files/Hotfixes/24.2/RecordingServer/Milestone.Hotfix.202506091048.RS.24.2.14120.1719.ReleaseNotes.txt
No WebAPI Compression hotfix for 24.1
milestonedownload.blob.core.windows.net/files/Hotfixes/23.3/RecordingServer/Milestone.Hotfix.202502281554.RS.23.3.96.1.220.ReleaseNotes.txt
XProtect 2023 R2 cumulative patch installers
XProtect 2023 R1 cumulative patch installers
milestonedownload.blob.core.windows.net/files/Hotfixes/22.3/RecordingServer/Milestone.Hotfix.202409131144.RS.22.33.73.177.ReleaseNotes.txt
XProtect 2022 R2 cumulative patch installers
XProtect 2022 R1 cumulative patch installers
No WebAPI compression hotfix for 21r2
XProtect 2021 R1 cumulative patch installers
This fix resolves the issues for Recording Servers that timeout while retrieving the configuration from the mgmt server during startup.
Please ask again in the support community, you should get better help from the partners using the support community.
Partner Support told me post here haha, but okay
