webplayer milestone
when i open milestone webclient to see stream of camers it can’t play and connection close and here are the logs
Signaling state: have-remote-offer
Signaling state: stable
ICE gathering state: gathering
ICE connection state: checking
Connection state: connecting
ICE connection state: connected
ICE gathering state: complete
Connection state: connected
Establishing connection time: 966 ms
ICE connection state: disconnected
Connection state: disconnected
Connection state: failed
Hi Mina,
I assume that you are talking about WebRTC sample - https://doc.developer.milestonesys.com/html/index.html?base=samples/protocolsamples/webrtc_javascript/readme.html&tree=tree_3.html
Can you please read above link? Especially “Set up WebRTC sample”, “Configuration files” and “API Gateway CORS settings”. CORS setting is important in order to run the sample.
Then please check if wellknown url is working. Please try this uri on a browser http(s)://{servername}/api/.well-known/uris and see if you can get a result. MIP Documentation about well-known/uris is this -https://doc.developer.milestonesys.com/mipvmsapi/api/config-rest/v1/#section/Introduction/Get-started.
