Hi team,
I am experiencing some troubles when trying to move to the lastest SDK version for a component integration app.
I am using VS2022 17.9.197, DotNet Framework 4.8, and trying to build the MetadataLiveViewer sample.
I get this warning
There was a conflict between “System.Text.Encodings.Web, Version=4.0.5.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51” and “System.Text.Encodings.Web, Version=4.0.5.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51”.
that turns into a runtine error when I try to use the sample with entityframeworkcore.sqlite (v3.1.32).
If I use VideoOS.Platform.SDK <=22.3.2 all is working and the warning disappears.
Any hint on how to fix this?
