I’m experimenting with the MIP SDK samples (MultiChannelMetadataProvider, MetadataLiveViewer, and MetadataPlaybackViewer) and I can’t seem to get the metadata to record. I can view it using MetadataLiveViewer. The Management Client shows the little 1’s and 0’s when data is sent, but it doesn’t seem to be recorded. I’ve let it run for an hour and the local storage used by the device doesn’t change. The MetadataPlaybackViewer doesn’t appear to find any data when it connects to the server.
Is there anything special I need to do to get it to record? The Recording checkbox is checked on the device settings Record tab.
I’m using the Corporate version 2020 R1.
