Please see
and
Note that if you do “managed c++” you can use the MIP .Net library much the same way the c# samples show. If this is an option I will recommend this.
Please see
and
Thank you for your fast reply. Do you know if I can use ImageView Demo ActiveX.htm sample? It´is not working fine.
Milestone XProtect Recording server v12.2a (x64)
Milestone XProtect Management Client 2018 R2 - v12.2a
There is some .OCX (activeX) that works fine with this server.
I want to view live video.
I have configure 1 camera
It is important to note that this sample only works when using Windows authentication users (in e-code servers which you have as you have a Management Client), not basic users.
