What OPC alert types exist?
Looking at the OPC integration manual at http://download.milestonesys.com/MTSKB/KB000033366/OPC_Interface_Manual.pdf
Under OPC Item Structure there is an item called Cameras//Latest alert type. What text can this item contain?
Please be aware that the OPC server is provided as is and is no longer under active support.
The “Latest alert type” can be any of the following values:
“Start”,“Stop”,“Camera not responding”,“Running out of disk space”,“Unit OK”,“Motion detected”,“External event”,“Archived failure”,“Archive move failure”,“Define engine”,“Add camera”,“Add PIR”,“Other”
