When I use bitmaplivesource, frame-rate is fixed at 1.
Hi guys.
I’m developing a software using bitmaplivesource and jpeglivesource.
When I used jpeglivesource, there was no problem. resize, cropping, fps change, all worked well.
My problem happened when I changed it to bitmaplivesource.
If the original video is mjpeg, no problem.
problem is if the original video is h.264 or h.265.
if I set fps argument to some specific fps, fps is fixed at 1.
I think this is a bug.
can you check about this?
I have reproduced your observation and will do further investigations.
A fix has been developed. The fix will be available in MIP SDK 2020R3 to be released later this year.
