When the device is deleted at the server, it does not enter the close() interface (hikdri verConnectionManager.cs )Because I want to be able to close some of my established connections when I delete the device. Please give me some advice.
look the picture below for the specific code.
Milestone Development will start an investigation.
​hello,Is there any progress on this issue?
No, there is no news to report, the case is with the developers but there is no feedback yet.
Thank you for your reply, because our project time is quite urgent, can you confirm it again?
I will check the status and let me back to you later.
There is no news to report, but I will get back to you as soon as I receive the news from the Development.
Which version and edition of the XProtect VMS are you using?
Also, which version of the SDK are you using?
Is there any progress on this issue? I have the same problem too.
Milestone Development fixed this issue and included in 2020 R3 MIP SDK which is releasing today. Please download it and try out.
