This parameter adds extra devices to the hardware, but only the first channel actually works.
_parameters.Add(“NumVideoCh”, “16”);
We would really need this to work soon, can you provide an estimation on when that would be?
Thank you.
Thank you.
It is not going to.
A case was opened that the driver or the driver documentation should be changed but instead of prioritizing the development work for change the decision was that this should not be changed.
