Where do user logins are stored?
When a user logins into the management server where do you save that event? A table in the database? It would be great if you can enlighten me in that workflow (user login / token). Thanks in advance!
The user logins is put in the Audit logs
https://developer.milestonesys.com/s/article/read-Audit-System-or-Rule-logs-from-the-MIP-SDK
Thank you for your answer. The logins that I make thru SDK are logged with Audit Log or only Smart Clients are logged?
It is every client, Management Client, Smart Client, Mobile Client, Web Client and MIP SDK based clients.
You can see the audit log in the Management Client under Server Logs - Audit logs - for a first impression.
