I have my Axis camera setup for highest res recording which is 2048x2048, but I only want the live view setup for 1200x1200, because the computer will freeze if live view of 16 cameras at 2048x2048, but no issue at all if 1200x1200. How do I setup view for 1200x1200 while recording is at 2048x2048?
I will explain how to set up multiple live stream and how to use them in SDK.
When you click Recording Server - Hardware - camera device in Management Client, there is a Settings tab in the right pane, you can see each stream resolution in the tab. Also there is a Streams tab, you can also set the stream that you use for the camera.
For example, when you use two streams then you set 2 Video stream in Streams tab and you can set Resolution in Settings tab.
So when you set multiple stream in MC, then you can select the stream that you use for SDK.
Thank you, that resolved the issue.
