Why does milestone not decode rtp over udp packet? The package caught by wireshark is in the attachment. Rtsp process in a detailed description
DESCRIBE rtsp://192.168.1.129:1554/realtime?id=0;aid=0;agent=onvif RTSP/1.0
CSeq: 1
Accept: application/sdp
User-Agent: CmRtspClient 10.0a.103
Bandwidth: 384000
RTSP/1.0 401 Unauthorized
CSeq: 1
WWW-Authenticate: Basic realm=“Keda Streaming Media”
CSeq: 2
Bandwidth: 384000
Authorization: Basic YWRtaW46YWRtaW4xMjM=
RTSP/1.0 200 OK
CSeq: 2
Content-Type: application/sdp
Content-Length: 511
v=0
o=NVR 1542012042 1542012042 IN IP4 0.0.0.0
s=3GPP Unicast SDP
c=IN IP4 0.0.0.0
t=0 0
a=range:npt=0-
a=control:*
m=video 0 RTP/AVP 96
a=control:video_0
a=rtpmap:96 H264/90000
a=fmtp:96 profile-level-id=64001f;sprop-parameter-sets=Z2QAH6zSAUAW6AbQoTU=,aO4G4sA=;packetization-mode=0
m=audio 0 RTP/AVP 102
a=control:audio_0
a=rtpmap:102 mpeg4-generic/16000/1
a=fmtp:102 streamtype=5; profile-level-id=15; mode=AAC-hbr; config=1408; SizeLength=13; IndexLength=3; IndexDeltaLength=3; Profile=1;
SETUP rtsp://192.168.1.129:1554/realtime?id=0;aid=0;agent=onvif/video_0 RTSP/1.0
CSeq: 3
Transport: RTP/AVP;unicast;client_port=6566-6567
RTSP/1.0 200 OK
CSeq: 3
Session: 1542012042;timeout=60
Transport: RTP/AVP;unicast;mode=play;client_port=6566-6567;server_port=56004-56005
Cache-Control: no-cache
PLAY rtsp://192.168.1.129:1554/realtime RTSP/1.0
Session: 1542012042
CSeq: 4
Range: npt=0.000-
RTSP/1.0 200 OK
CSeq: 4
Session: 1542012042
RTP-Info: url=video/id=0;seq=0;rtptime=0,url=audio/id=0;seq=0;rtptime=0
Range: npt=0.000-
Date: Mon, Nov 12 2018 16:40:42 GMT
OPTIONS rtsp://192.168.1.129:1554/realtime?id=0;aid=0;agent=onvif RTSP/1.0
CSeq: 5
Session: 1542012042
RTSP/1.0 200 OK
CSeq: 5
Session: 1542012042
Public: OPTIONS, DESCRIBE, SETUP, PLAY, PAUSE, TEARDOWN,GET_PARAMETER, SET_PARAMETER
TEARDOWN rtsp://192.168.1.129:1554/realtime RTSP/1.0
Session: 1542012042
CSeq: 6
RTSP/1.0 200 OK
CSeq: 6
Session: 1542012042
Attachment is software version information
This is not related to developing integrations using the MIP SDK. This is a question suited for the Milestone Support Community.
PS. If you are a Milestone Camera Partner try to contact your contact in the Milestone Partner team, the partner team might have some guidance documents.
