Hello
My Event Server background plugin needs to store and read it’s files on local disk drive. It requires own folder with Network Service full access permissions (since it runs on Event Service env).
To avoid using custom config with folder path and to avoid setting up and managing permissions for plugin’s folder I am going to use already exist Event Server folder which has required permissions:
[C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Event Server
and just create there my own “MyPlugin” folder
Could you help me with this:
- Is that path static for all Event Server installations?
- If no - Is there a way for background plugin to programatically retrieve that path?
