Hello, I wrote to know if you could tell me how to add an event and alarm window just like in the alarm manager tab, in addition to adding a button to be able to select that event and perform tasks on it, I was also wondering if Could you tell me where I can find the associated documentation where it indicates that it is possible to add to the workssapace in order to be able to review it and add what I need. Greetings, thank you all.
I’m not sure if this will answer you question, but I would suggest that you start out by looking at our Plugin Samples, like the
For workspaces, this samples shows how that is done:
Working with events can be seen here:
This samples works with alarms and could be usefull as well:
I hope the above can get you started. If you have any specific question about calls or how do specific tasks, please reach out again
