Writing a script to export archived videos to MKV
I need to convert existing archived videos to MKV, but not manually using Smart Client since there are many hours of existing videos. I want to know if I could write a script or a component to automate this, as in I could specify the camera and time range in command line interface. Maybe there’s something already existing, but I can’t seem to find any information.
Thank you.
There is no tool that does what you ask. You can however develop such a tool. I recommend that you explore the Export Sample.
https://doc.developer.milestonesys.com/html/index.html?base=samples/export_sample.html&tree=tree_2.html
