Wrong key's property name in Camera StreamChildItem
as you can see in the follow image
you can see the DeviceDriverSettingsChildItem properties.
The attribute Keys and the attribute KeysFullName contains different strings so I can take the name of properties and his key for the values.
In the follow image
you can see the StreamChildItems properties, the attribute Keys and the attribute KeysFullName contains same strings so I can’t take the name of properties.
It is a bug? or there is another attribute to take the name of the property?
I’m using SDK 2019 R1 and XCO 2018 R3.
Thanks in advance
Allow me to get back on this one. I am consulting Milestone Development.
Milestone Development will not change this, if it is changed it might break integrations already developed.
