We have the below project we would like to implement with Milestone 2018 R2 however we have run into a roadblock. We are attempting to use our exception reporting site to pull video from a specific register biased on the receipt information. We have managed to set up their site to retrieve the data with the use of the Milestone SDK however we are getting an Access Denied when we try to retrieve the video. Currently the test recording server is what is being used access the analytics site so it does not appear to be a network issue. I have checked the security settings on the system and can see no issues there. The below is the result.
Console message: " Sending Connect on Mon Aug 27 2018 16:11:53 GMT-0400 (Eastern Daylight Time)with [object Object] "
Function: XPMobileSDK.library.Ajax
URL: “http://10.242.73.5:8090/XProtectMobile/Communication”
method “POST”
postBody “<?xml version=\\"1.0\\" encoding=\\"utf-8\\"?><Communication xmlns:xsi=\“http://www.w3.org/2001/XMLSchema-instance\” xmlns:xsd=\“http://www.w3.org/2001/XMLSchema\”><Command SequenceId=\“1\”>RequestConnect<Param Name=\“PublicKey\” Value=\“ViMddRloYxrVmxqfcY8KeMo/M4iOhs5boINEMoJZZbk4gX/J3S/7B9+W7tDX/teyNRNgDQ9/zrPypZD1tVh2dyMZf5VBdanb4V9EUyLA5d54+CgV0vEDdALTzG7SjSc+xJ1ZXHXHYS9lIqxo+h5tgOQWxjT5GGReua2/ilYWOMsA\” /><Param Name=\“PrimeLength\” Value=\“1024\” /><Param Name=\“EncryptionPadding\” Value=\“ISO10126\” />\r\n\r\n”
responseType “text”
Error returned: “Access is denied.”
