No.
There might be firewall or similar. Also consider that you must login (I wonder if you on local could be current user).
Login see - http://doc.developer.milestonesys.com/html/index.html?base=samples/logindotnetsoap.html&tree=tree_3.html
You cannot change password on Server Command but you can on Configuration API
