We use Milestone 2019 R2 version. When I try to add new recording server see this response :
Check the management server hostname and the connectivity to the server.
I noticed that on the manegment server IDP dosen’t work
what can be problem my management server ?
2022-04-24 14:22:53.982+03:00 [ 57] ERROR - Grant validation error: No authentication handler is registered for the scheme ‘Windows’. The registered schemes are: idsrv, idsrv.external, Bearer. Did you forget to call AddAuthentication().Add[SomeAuthHandler](“Windows”,…)? System.InvalidOperationException: No authentication handler is registered for the scheme ‘Windows’. The registered schemes are: idsrv, idsrv.external, Bearer. Did you forget to call AddAuthentication().Add[SomeAuthHandler](“Windows”,…)?
at Microsoft.AspNetCore.Authentication.AuthenticationService.AuthenticateAsync(HttpContext context, String scheme)
at VideoOS.IdentityServer.GrantValidators.WinAuthGrantValidator.ValidateAsync(ExtensionGrantValidationContext context) in [C:\w1\80c4195c9cc76a85\IdentityServer\VideoOS.IdentityServer\GrantValidators\WinAuthGrantValidator.cs](file:C:/w1/80c4195c9cc76a85/IdentityServer/VideoOS.IdentityServer/GrantValidators/WinAuthGrantValidator.cs):line 29
at IdentityServer4.Validation.ExtensionGrantValidator.ValidateAsync(ValidatedTokenRequest request)
2022-04-24 14:22:54.144+03:00 [ 57] ERROR - Invalid extension grant: invalid_grant
2022-04-24 14:22:54.300+03:00 [ 57] ERROR - {
“ClientId”: “winauthclient”,
“GrantType”: “windows_auth”,
“Scopes”: “write:client”,
“Raw”: {
“grant_type”: “windows_auth”,
“scope”: “write:client”,
“client_id”: “winauthclient”
