I have just updated my lab milestone with 2020R3 to check compatibility with my own plugin. Generally when starts SmartClient, in AlarmManager tab is shown default Map with icons to select home map and to choice other maps. After upgrade to 2020R3, opening Smart Client, no more map icons appairs also if no alarms are active. Exists some options to set up and activate default map ?
The problem is this: the behavior of the Smart Client is different from that of previous versions of Milestone XP. The possibility for the operator to choose a map even in the absence of alarms is required for sensor management even without alarms. If the smart client does not show the map, the operator cannot manage the sensors until an alarm is shown. One of the main features of our plugin is that the operator can give commands to the sensors directly from the commands of the customized context menu. Without a map … it’s a bit difficult
If you do not have an alarm the Alarm Manager workspace will neither show Alarm Preview nor Map, this is the behavior and in my opinion it would be very confusing if changed. The workaround is to make a view that includes Map. In this way the user can always reach the map even if there are no alarms, or there are alarms using a different map.
