I am currently running Milestone XProtect Corporate 2020 R3 in my production environment, and I would like to upgrade this system to XProtect 2025 R3.
I would appreciate your guidance on the recommended and supported upgrade path.
My current environment:
Live production system
Separate servers for:
Management Server
Recording Server(s)
SQL Server (SQL Server 2019 Express)
Approximately 70 IP cameras
Recordings must be preserved during the upgrade
My questions:
Is a direct upgrade from 2020 R3 to 2025 R3 supported, or is an intermediate upgrade (for example to 2023 R3) required?
What is the recommended upgrade order for a distributed setup (Management Server, Recording Servers, SQL Server)?
Are there any specific precautions or best practices I should follow to avoid recording or configuration loss during the upgrade?
Thank you in advance for your support.
Kind regards,
CAN GÜLER
