32 bit 2021 R1 SDK, is it available?Thanks
I discovered that the download is available when you are logged in as a partner, in your partner portal, but not if you just use the section where everybody can download. I will find out if this is intentionally. Meanwhile use the link here - http://download.milestonesys.com/MIPSDK/MIPSDK_Redist_Installer_x86_2021R1.msi
