We display IP camera video obtained via the WebRTC REST API on video panels on a dashboard.
There is no issue when the dashboard has a single video panel, but when attempting to display simultaneously on two or more video panels,
XProtect returns a 400 Bad Request RESPONSE to the REQUEST (POST /api/xprotect/v1.0/session), and the video display may fail.
We will provide the following information; please identify the cause and propose countermeasures:
- Environment information
- REQUEST and RESPONSE details for both successful and failed cases
- Excerpts of the relevant portions of the XProtect API Gateway DEBUG log
■Environment information
Using WebRTC in XProtect Professional+ 2024 R2
camera01 Id: f131f2e3-fd8d-457a-8d6d-858418301b1d
camera02 Id: c278841f-d97e-4311-a59b-a04ef8d469e1
■Successful REQUEST
POST /api/xprotect/v1.0/session HTTP/1.1
Accept: */*
Accept-Encoding: gzip, deflate, br, zstd
Accept-Language: ja,en;q=0.9,en-GB;q=0.8,en-US;q=0.7
Cache-Control: no-cache
Connection: keep-alive
Content-Length: 252
Content-Type: application/json
Cookie: i18next=ja; timeLineRange=%7B%22from%22%3Anull%2C%22to%22%3Anull%2C%22select%22%3A%22live%22%7D
Host: 192.168.1.155:8443
Origin: https://192.168.1.155:8443
Pragma: no-cache
Referer: https://192.168.1.155:8443/panel_groups?id=2e0be14c-0de1-4506-a3de-30890013ea1a
Sec-Fetch-Dest: empty
Sec-Fetch-Mode: cors
Sec-Fetch-Site: same-origin
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0
sec-ch-ua: “Microsoft Edge”;v=“141”, “Not?A_Brand”;v=“8”, “Chromium”;v=“141”
sec-ch-ua-mobile: ?0
sec-ch-ua-platform: “Windows”
“deviceId”: “c278841f-d97e-4311-a59b-a04ef8d469e1”,
“cameraId”: “c278841f-d97e-4311-a59b-a04ef8d469e1”,
“playbackTimeNode”: {
"playbackTime": "2025-12-06T15:00:00.000Z",
"skipGaps": false,
"speed": 1
“iceServers”: [],
“resolution”: “notInUse”,
“includeAudio”: false
※Note: To support both XProtext 2024 R2 and 2025 R2, we are POSTing both deviceId and cameraId.
■Successful RESPONSE
HTTP/1.1 200 OK
Server: nginx/1.27.1
Date: Sun, 07 Dec 2025 23:35:19 GMT
Content-Length: 1810
access-control-allow-origin: https://192.168.1.155:8443
access-control-allow-credentials: true
vary: Origin
{“sessionId”:“1b85f631-6496-4066-944b-6c5873f4abb9”,“offerSDP”:“{\“type\”:\“offer\”,\“sdp\”:\“v=0[\\r\\no=-](file://r//no=-) 98502 0 IN IP4 127.0.0.1[\\r\\ns=sipsorcery\\r\\nt=0](file://r//ns=sipsorcery//r//nt=0) 0[\\r\\na=group](file://r//na=group):BUNDLE 0 1[\\r\\nm=video](file://r//nm=video) 9 UDP/TLS/RTP/SAVP 101 102 103[\\r\\nc=IN](file://r//nc=IN) IP4 0.0.0.0[\\r\\na=ice-ufrag](file://r//na=ice-ufrag):KFVJ[\\r\\na=ice-pwd](file://r//na=ice-pwd):QAEAGKYMDZLYIQIERAOODEIX[\\r\\na=fingerprint](file://r//na=fingerprint):sha-256 EA:EC:5F:D5:54:A9:BA:A5:CA:75:C5:F1:C0:E4:E6:BB:30:5E:F7:2A:F6:F4:99:51:07:57:3E:7B:82:5B:8A:66[\\r\\na=setup](file://r//na=setup):actpass[\\r\\na=candidate](file://r//na=candidate):1266949509 1 udp 2113937663 192.168.1.154 64242 typ host generation 0[\\r\\na=ice-options](file://r//na=ice-options):ice2,trickle[\\r\\na=mid](file://r//na=mid):0[\\r\\na=rtpmap](file://r//na=rtpmap):101 H264/90000[\\r\\na=rtcp-fb](file://r//na=rtcp-fb):101 goog-remb[\\r\\na=fmtp](file://r//na=fmtp):101 packetization-mode=1;level-asymmetry-allowed=1;profile-level-id=42e01f[\\r\\na=rtpmap](file://r//na=rtpmap):102 H264/90000[\\r\\na=rtcp-fb](file://r//na=rtcp-fb):102 goog-remb[\\r\\na=fmtp](file://r//na=fmtp):102 packetization-mode=1;level-asymmetry-allowed=1;profile-level-id=42e034[\\r\\na=rtpmap](file://r//na=rtpmap):103 H264/90000[\\r\\na=rtcp-fb](file://r//na=rtcp-fb):103 goog-remb[\\r\\na=fmtp](file://r//na=fmtp):103 profile-level-id=42e01f[\\r\\na=extmap](file://r//na=extmap):2 http://www.webrtc.org/experiments/rtp-hdrext/abs-send-time\\r\\na=rtcp-mux\\r\\na=rtcp:9 IN IP4 0.0.0.0[\\r\\na=end-of-candidates\\r\\na=sendonly\\r\\na=ssrc](file://r//na=end-of-candidates//r//na=sendonly//r//na=ssrc):1998986647 cname:f70e8f7b-5e18-495a-bfde-8c25fa98cfb6[\\r\\nm=application](file://r//nm=application) 9 UDP/DTLS/SCTP webrtc-datachannel[\\r\\nc=IN](file://r//nc=IN) IP4 0.0.0.0[\\r\\na=ice-ufrag](file://r//na=ice-ufrag):KFVJ[\\r\\na=ice-pwd](file://r//na=ice-pwd):QAEAGKYMDZLYIQIERAOODEIX[\\r\\na=fingerprint](file://r//na=fingerprint):sha-256 EA:EC:5F:D5:54:A9:BA:A5:CA:75:C5:F1:C0:E4:E6:BB:30:5E:F7:2A:F6:F4:99:51:07:57:3E:7B:82:5B:8A:66[\\r\\na=setup](file://r//na=setup):actpass[\\r\\na=ice-options](file://r//na=ice-options):ice2,trickle[\\r\\na=mid](file://r//na=mid):1[\\r\\na=extmap](file://r//na=extmap):2 http://www.webrtc.org/experiments/rtp-hdrext/abs-send-time\\r\\na=sctp-port:5000\\r\\na=max-message-size:262144\\r\\n\”}”,“answerSDP”:“Uninitialised”,“playbackTimeNode”:{“playbackTime”:“2025-12-07T23:35:27.119Z”,“skipGaps”:false,“speed”:1.0},“includeAudio”:false}
■Failed REQUEST
Accept: */*
Content-Length: 252
Pragma: no-cache
“deviceId”: “f131f2e3-fd8d-457a-8d6d-858418301b1d”,
“cameraId”: “f131f2e3-fd8d-457a-8d6d-858418301b1d”,
"skipGaps": false,
"speed": 1
“iceServers”: [],
■Failed RESPONSE
HTTP/1.1 400 Bad Request
Content-Length: 42
vary: Origin
{“error”:“Request failed with status 400”}
■Excerpts of the relevant portions of the XProtect API Gateway DEBUG log
I have attached gateway-0002.log.
The relevant section is from 2025-12-08 15:14:14.779+09:00 to 2025-12-08 15:14:40.888+09:00.
