A Question Around Advanced Reporting Using SQL Queries and MS Logs
We can access the Rule and Audit logs on the MC. The statistics provided within these reports are somewhat basic. Based on what we can see we can access the data we need within the Surveillance DB. My question is, does anyone know of any SQL queries we can run to pull this kind of data into a workable form? Essentially we need to be able to determine the below
Operator Name
Signal ID
Time Alarm was viewed
Reason for closing (we have that configured)
Amount of alarms in the “new” stack at the time of the signal in question
Alarm lifespan (time alarm was on in the “new” stack)
The SQL Server is not documented and not supported. If you build an integration on querying the SQL it can potentially break when Milestone makes a new version as Milestone can change the design without notice.
There are methods in the MIP SDK for reading information. For reading the logs please see:
https://developer.milestonesys.com/s/article/read-Audit-System-or-Rule-logs-from-the-MIP-SDK
