- A way to extract per camera status (availability, recording status, any other status, events or alarms) from the Milestone system on a relatively frequent basis (performant). - Is there A means of doing this without having to code in .NET.
- If there isn’t an alternative to fulfilling the requirements without .NET, then sample code would suffice.
We have a number of samples that can do this, but most samples are .NET, if not using .NET you will have to use protocol methods and the Status SOAP Protocol. https://doc.developer.milestonesys.com/html/index.html?base=statushelp/index.html&tree=tree_3.html
.NET samples: https://developer.milestonesys.com/s/article/exploring-the-MIP-SDK-recommended-top-SDK-samples
