About Plugin Language
I have developed a multilingual plugin that operates in the Smart Client, Administration and Service Environments. The Plugin chooses the language according to the client settings, both SC and MS, but the Event Server assumes the language of the Operating System, therefore the definitions of the Events (Triggers) managed by the Plugin always remain in the language of the OS, even if the client part of the plugin tries to nationalize these definitions.
I saw that changing the language of the MC the other definitions of the Events appear in the language of the client, so I assume there is a way to redefine them, please can someone show me how to do it?
Many Thanks,
Frediano
If there are common events that Milestone defined, then it is possible to change the language. But if you have your own events, unfortunately it is not possible to do it.
Rie,
thank you for answer.
The plugin is for manage a Security Panels family of an Italian manufacturer, so it’s obvious that has it’s own Events (5 different categories), so the only way is to configure the language and use the chosen one, independently from that of the clients and the operating system.
Regards,
Frediano
