About XProtect VMS: When using SDK connect to Milestone VMS Server? Any audit log record to trace back the activity in XProtect?
Dear Support,
When using SDK connect to Milestone VMS Server? Any audit log record to trace back the activity in XProtect? e.g. someone connect to XProtect to get live stream / playback / check record status, etc..
If yes, this audit log is milestone internal logging in database or store in a text file? How can we retrieve for analyze case (SDK connection)?
Thank you for your support!
BR,
Engine
This is written to the XProtect audit logs which can be accessed using our SDK. Please refer to this sample for an example on how to do it: https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/logread/readme.html&tree=tree_2.html
Thank you for your reply! If no audit log access / write in SDK connection design, XProtect will no record to trace back (any activity / request after authorization)? Any hint in XProtect inside can helpful to match the activities of SDK connection request? Thank you!
I am not sure I understand your question, but a number of different things are logged in the audit logs, including logon, video access, etc. However, we do not distinguish between whether the logon/access has been done through an SDK integration or through e.g. Smart Client.
