Access control in smart client 2017 R3
I have problem with server Milestone Essential+ in free license.
In communication between me and server i found this.
401 \\226 Neautorizov\\341no: P\\370\\355stup byl odep\\370en v d\\371sledku neplatn\\375ch p\\370ihla\\232ovac\\355ch \\372daj\\371.
\\r\\n
Nem\\341te opr\\341vn\\354n\\355 k zobrazen\\355 tohoto adres\\341\\370e nebo str\\341nky pomoc\\355 zadan\\375ch p\\370ihla\\232ovac\\355ch \\372daj\\371.
\\r\\n \\r\\n \\r\\n
That means - “Unauthorized: Access was deny, because you have bad login/password. You dont have permision for view this adress or webpage using by this login/password”
But im sure the login with password is correct. Basic user was create after completed install Milestone Essential+ and he is in role “Administrators”. Password added..
PUBLIC ACCESS IS ENABLED WITH RIGHT PUBLIC IP
On router is setting <wan_ip>:2323 → <local_ip>:80 and others ports like:
<wan_ip>:8081 → <local_ip>:8081
<wan_ip>:8082 → <local_ip>:8082
<wan_ip>:7563 → <local_ip>:7563
<wan_ip>:22331 → <local_ip>:22331
<wan_ip>:1237 → <local_ip>:1237
<wan_ip>:9001 → <local_ip>:9001
On webpage in chrome <wan_ip>:2323 is “IIS Windows Server”
And everything works in LAN, but access from WAN has this problem on Smart client 2017 R3. Mobile and webpage version on ports 8081,8082 works great.
For login in SMART CLIENT 2017 R3 im using
PC: <WAN_IP>:2323
verification: basic authentication
login/password: /
Im really sorry for my bad english and thanks for help..
I suspect networking/routing/DNS is the issue. Please note that Web client and mobile clients are designed with WAN usage in mind, the Smart Client is not. Most often I see Smart Client used together with some sort of VPN that solves all the routing.
https://force.milestonesys.com/support/MccSupportCommunity
