Hi, I have configured my access control plugin to require authentication to the access control system. In the management client I have checked “Operator login required”. In the Smart client this causes a secondary access control login screen to appear after the initial login. This secondary login screen is not shown when using the Mobile client though. I am trying to figure out why.
Is there any additional configuration needed for the Mobile client to get the secondary login to the access control system to work?
Thanks,
-Lou
P.S. In case it helps, the following was in the log file [C:\ProgramData\Milestone\XProtect Mobile](file:C:/ProgramData/Milestone/XProtect%C2%A0Mobile) Server\Logs:
2020-04-30;3:20:17 PM;Error;RequestCallback;Cannot access a disposed object.
Object name: ‘System.Net.Sockets.Socket’.
2020-04-30;3:20:18 PM;Info;LicenseWrapper;OnlineExpiration is True
2020-04-30;3:20:18 PM;Error;RequestCallback;Cannot access a disposed object.
2020-04-30;3:20:18 PM;Error;System.Exception: Preconditions not met for group HTTPS; at VideoOS.Mobile.Server.Service.MetaChannel.PluginGroup.Start(Dictionary`2 settings)
2020-04-30;3:20:18 PM;Info;PluginManager.Start();This error might occur due to an incorrect HTTP/HTTPS channel configuration
2020-04-30;3:20:18 PM;Info;AccessControlManager.LoadAccessControlSystems;Access Control system “Access It_ Universal_NET” was skipped. Personalized login is enabled
2020-04-30;3:20:21 PM;Error;DeviceScanner.RequestCallback;Cannot access a disposed object.
