In the MIP SDK, I wasn’t able to find a WSDL for ImageServer (to retrieve live camera feed from Milestone). I’ve found the documentation for it here though:
However, a WSDL pertaining to all those requests (using SOAP) isn’t available in the SDK.
Reason for asking - I wanted to try out Genivia’s gSOAP toolkit against the given WSDLs so that I could get the Milestone’s Protocol Integration to work on my linux application.
Oh, okay. Thanks for the answer. If that is the case, where can I find more information on the Request for Live camera data from Milestone. For instance, if I want to request for h.264 data to be sent as is (instead of JPEG) using Protocol Integration, how do I do that?
Eg: For MIP, I can specify it in the config (with the is)
