To get live images from camera, I tried to run VideoViewer, MediaLiveViewer and mediaRGBVideoEnchancementLive examples which are in Component Samples. But when the camera connection is done, I get an Access violation error and the program closes.
Do you know why this error occurs and what would be the solution for this?
We tried to reproduce the issue with 2020 R2 SDK, but could not.
Could you please provide some more details regarding the exception, operating system? Are you using VM or physical machine? Which version and edition of XProtect are you using?
