Accessing Camera from Milestone Server
I have configured some cameras in Milestone smart Client ,I want to access these cameras on the web browser globally without using mobile server or web client.?
Is this possible ?
If you develop something to replace the Mobile Server and Milestone clients then it is possible. Out of the box accessing a camera globally on a browser would require you to use Mobile Server and web client. I hope this answers your question.
Can i access the web client without authentication .?
You could use cURL to authenticate behind the scenes.
i could not understand can you explain me can i access the web client without username and password
