Hi all, I’m integrating Milestone into an existing system of ours and will require the IP address of the cameras that Milestone is aware of. I see there’s a pre-release of a REST API that’s been posted, does anyone know if there is an endpoint that allows you to query a camera by GUID and get its metadata, including its IP address? Thanks for any help.
As you posted already, you need to get IP from hardware.
FYI 1 ) Following is for camera information.
FYI 2 ) – You might already see this documentation but let me introduce it to you.
@Rie Kiuchi (Milestone Systems) @Frediano Maria Di Carlo (SecurSys S.a.s.) Thank you both!
