add deviceID using SDK
 Is posible add deviceID using SDK in Milestone Corporate 2016?
Regards,
Dario.
Add a deviceID?
Perhaps you want to add a camera onto the XProtect Corporate VMS as you would normally do in the Management Client. (?)
If that fits then I recommend that you explore the Config API Client sample in the MIP SDK.
Yes is correct, I need add a camera name from third party software to Milestone Corporate. Can I use the sdk to make it? or exists any API? or isn´t possible do it?
Regards,
Darío.
Yes, it is possible with the Configuration API which was introduced in XProtect Corporate and Expert 2014 and greatly improved in XProtect Corporate and Expert 2016R2
