I try to use "[Protocol Integration Sample - Analytics Event Trigger via XML](https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdoc.developer.milestonesys.com%2Fhtml%2Findex.html%3Fbase%3Dsamples%2Fanalyticseventxml.html%26tree%3Dtree_3.html&data=04%7C01%7C%7Cdba10bb36e35471b83e208d89ce0bb2a%7C4744e4b2072d4754be71250b45e049fe%7C0%7C0%7C637431836433898688%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=7OpjRCKwYcOYryeV39mFM%2B40hKoAYD8ouYEn1zN43WM%3D&reserved=0 "https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdoc.developer.milestonesys.com%2Fhtml%2Findex.html%3Fbase%3Dsamples%2Fanalyticseventxml.html%26tree%3Dtree_3.html&data=04%7C01%7C%7Cdba10bb36e35471b83e208d89ce0bb2a%7C4744e4b2072d4754be71250b45e049fe%7C0%7C0%7C637431836433898688%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=7OpjRCKwYcOYryeV39mFM%2B40hKoAYD8ouYEn1zN43WM%3D&reserved=0")" to send the analysis event to Milestone Event server.
I has successful to create the analysis event with the bounding box but I can’t find the way to append other extra attributes to analysis event(Ex: “name”, “age”, “group”, thumbnail image … etc ).
I has try to add the “CustomTag” to the event xml, but it doesn’t display in the Alarm Manager.
I has found the demo from Milestone Systems Learning(https://www.youtube.com/watch?v=KKSKEFoe6A8&t=704s)
I found it can add the extract attributes “Tag” on the event and it can search on alarm manager.
I want to add extra attributes like the “Tag” and append the person thumbnail like the sample on above.
Would you please tell me what should I do then we can do the same thing like below demo ?
I has attach my testing xml on the end of the question and below is the snapshot of my XProtect Smart Client Alarm Manager.
Continue the previous question, if it can add extra attributes to the analysis event.
Can it be searched at the XProtect Smart Client Search filter ?
What should I do to make the user can search video clip by the person attribute ?
Or what is your suggest for the facial recognition best practice to define the search filter ?
I use **Test Analysis Event.txt** to send the analysis event.(The xml body contain overlap object)
But I can’t found the overlap bounding box or name on XProtect Smart Client live streaming or playback, it can only be seem on the Alarm Manager in my environment.
I has found the demo (https://www.youtube.com/watch?v=1TsRGHnm8lw) form the internet but I can’t reproduce on my environment.
Can the analysis event draw the overlap bounding box and name to the XProtect Smart Client live streaming or playback ?
Continue the previous question, can I control the stay time of overlap bounding box ? -
I has reference the sample code to send the [analytics event](https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdoc.developer.milestonesys.com%2Fhtml%2Findex.html%3Fbase%3Dsamples%2Fanalyticseventxml.html%26tree%3Dtree_3.html&data=04%7C01%7C%7Cdba10bb36e35471b83e208d89ce0bb2a%7C4744e4b2072d4754be71250b45e049fe%7C0%7C0%7C637431836433938672%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=uBtT44SMbbgI2kFvfBmFCytliJmOlQ17Kj8TVg%2B9%2BRw%3D&reserved=0 "https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdoc.developer.milestonesys.com%2Fhtml%2Findex.html%3Fbase%3Dsamples%2Fanalyticseventxml.html%26tree%3Dtree_3.html&data=04%7C01%7C%7Cdba10bb36e35471b83e208d89ce0bb2a%7C4744e4b2072d4754be71250b45e049fe%7C0%7C0%7C637431836433938672%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=uBtT44SMbbgI2kFvfBmFCytliJmOlQ17Kj8TVg%2B9%2BRw%3D&reserved=0") , but I can’t found the any way to append the access token (get from login API).
Is analytics event need to append the access token ?
