We are using Milestone Corporate 2017 R2 we would like to add the hardware device (cameras) through the CVS File how can we achive this kindly let us know
thanks
zafar
thanks
zafar
In XProtect Enterprise, Professional and Express you have an option in the Add hardware wizard to import cameras from a CSV file. This functionality does not exist in XProtect Corporate, Expert, Professional+, Express+ and Essential+. But in these product versions you have a Configration API. The MIP SDK sample Configuration API Import is showing how automated adding of cameras based on information in a file can be acchieved.
Dear Andersen,
thanks for your reply much appreciated!
Can you please share the link to follow the steps MIP SDK Sample Configuration API Import
Assuming you have the MIP SDK you will have to read about the sample in the MIP SDK Documentation. Find it as one of the component samples.
If you do not have the MIP SDK, but is a developer and would like to use this, you will have to first get the MIP SDK.
