is it possible to add hardwares using IPv6 ranges in XProtect Express+?
Thank you,
Thank you,
If you want to develop the functionality similar to that of the Management Client -Add Hardware wizard –Address range scanning you will have to implement a loop, the Configuration API or Rest API offers only functionality for one address at a time.
If using Rest see the AddHardware task here.
If using the Configuration API strongly typed (VideoOS.Platform.ConfigurationItems) classes see AddHardware here
If this question is not related to software development with the MIP SDK or XProtect integration in general, which is the focus of this forum, please ask again in a technical support case.
Support cases interface is found following this link. https://support.milestonesys.com/
