Hello, I am currently trying to add a server and log in with the Windows user, when I run the event trigger example I logged in without problem as shown in the image below
The problem is that this identification is through an external form of the library, I would like to do it manually by code
logging reports the error credentials used to get a token is invalid.Host name: localhost’ I am not very clear where the problem may be, I probably know something simple that I have not finished detecting. I would appreciate it if someone could tell me where the problem is, thanks
