Add usercotrol to custom workspace.
I have followed the example in SCWorkspace plugin example but cannot appear to get my custom usercontrol working. I’m using the sample as my base but have chnaged this part. I just want to fill the view with one user control and not multiple controls or views.
            rectangles.Add(new Rectangle(0, 0, 300, 300));
            ViewAndLayoutItem.Layout = rectangles.ToArray();
            ViewAndLayoutItem.Name = Name;
            ////add viewitems to view layout
            //List<Item> cameraItems = new List<Item>();
            //for (int i = 0; i < MAX_MAX_CAMERA_COUNT; i++)
            //    string configurationString = GetProperty("Camera" + i);
            //    if (String.IsNullOrWhiteSpace(configurationString))
            //        Dictionary<String, String> properties = new Dictionary<string, string>();
            //        FindAllCameras(Configuration.Instance.GetItemsByKind(Kind.Camera), cameraItems);
            //        properties.Add("CameraId", Guid.Empty.ToString());
            //        ViewAndLayoutItem.InsertBuiltinViewItem(i, ViewAndLayoutItem.CameraBuiltinId, properties);
            //    else
            //       ViewAndLayoutItem.InsertViewItem(i, configurationString);
            ViewAndLayoutItem.InsertViewItemPlugin(rectangles.Count - 1, new SCWorkSpaceViewItemPlugin(), new Dictionary<string, string>());  //want to utilize the whole view area.
If I may suggest, try to start with the Property plugin sample instead. In that sample you do not start by building a complex layout, it sounds more to be what you seek.
