Hi, I would like to add information on “inputs” from an access control system. For example a smoke detector. There are two states, “enabled” and “disabled”. These inputs have nothing to do with a door. Can this be done somehow with the MIP Access Control plugin?
One idea is to add another tab to the existing tabs (Events, Doors, Cardholders) called “Inputs”. See below for the existing UI.
That would allow the user to see all the inputs and the current state, similar to what is done with doors.
If that isn’t possible, is there a way to achieve this using the existing Doors section? Or, let me know if there’s another better way. Thanks,
-Lou
