curl --location --request PATCH 'https://redacted/API/rest/v1/alarms/97848faf-dba3-4381-81aa-82828f16907a' \
--header 'Authorization: Bearer redacted' \
--header 'Content-Type: application/json' \
--data '{
"priority": "34f1f987-6854-44fb-88a5-daa0add1e38a",
"state": "60ab3977-090a-4381-a644-8bb51af2fdaa",
"assignedTo.displayName": "some-value",
"reasonForclosing": null,
"comment": "test comment 1"
Results in two entries appearing in the alarm’s activities section in Milestone XProtect Smart client: one with the comment and one indicating that assignee changed.
--data '{
"assignedTo.displayName": null,
"comment": "test comment 2"
which unlike the previous one doesn’t specify assignee, but still specifies a comment, results in no new entries in the activities section.
Both requests return 202 Accepted.
Because the first one results in two entries, and one can add just a comment through Milestone XProtect Smart Client GUI, I expected to just be able to add a comment without having to modify other fields when using REST API. How do I accomplish this?
I am using version 2023R3
