Hi support,
In the Access Control plugin, is it possible to add an input Textbox/DateTimePicker when clicking door commands on the Smart Client?
We want to include this feature because we need to send a command to Lock/Unlock the Door with a DateTime parameter value.
Hello Binh,
This is currently not possible. What you can do as a workaround is to decide on several useful time intervals and make separate commands that open the door for that many minutes. This means having commands like “Unlock door for 5 minutes”, “Unlock door for 10 minutes” etc.
We will consider adding possibility for input to commands for future releases.
