Admin Plugin Node without childs, use the GenerateUserControl() only
Is it really not possible to render only the main plugin root node (MC) and use GenerateUserControl from the plugin definition to load a custom control for my needs?
I do have item managers, but I want to hide them and manage everything inside our own control. However, when I set the PlacementHint to hide them from the left tree, even the plugin node itself is no longer shown because it has no visible children.
That feels a bit crazy to me, because this seems like the perfect use case for WebUI-style plugins, where you just want to show your own UI instead of exposing individual item managers in the tree.
Is there really no solution for this? I would love to have one.
Big thanks!
Hi Christoph
Might be me not getting entirely what you you want to achieve but isn’t the ServiceTest sample doing what you ask? MIP SDK Documentation
Br,
Peter
Hi Peter,
Oh looks like its exactly what i wanted, strange, I will explore the diffrence, may its because I have an ItemManger added but hidden what force it then to hide the root node. Basically its exactly what i want just one custom control at rool level node click but underhood have serval mip items eg item manager with placement hint set to HiddenInLeftTree.
BR
ok this works only when no item managers are definied, if I add one the plugin node is not visible and is gone.
