AI Bridge Latitude/Longitude Mix up?
Hi there,
I’m running the AI bridge v2.0.3, and I’m seeing latitude and longitude mixed up.
If I look at the Milestone configuration interface, it doesn’t specifically say which is which, but given latitude is -90 to +90 and longitude is -180 to +180, one would assume given the example that it’s latitude first, and longitude second.
The AI bridge, when queried, reverses the information, returning latitude as longitude, and vice versa.
Query:
query {
  cameras(deviceIDs: ["8e3f96cb-ca83-4f54-abe5-d4da0ebbe5b2"]) {
    id
    geographicPosition { latitude longitude }
Response:
  "data": {
    "cameras": [
        "id": "8e3f96cb-ca83-4f54-abe5-d4da0ebbe5b2",
        "geographicPosition": {
          "latitude": 151.206669,
          "longitude": -33.871435
If I query the SOAP service on the server (/ManagementServer/ServerCommandService.svc), I get a value like so:
  <DeviceId>8e3f96cb-ca83-4f54-abe5-d4da0ebbe5b2</DeviceId>
  <DeviceIndex>0</DeviceIndex>
  <GisPoint>POINT (151.206669 -33.871435)</GisPoint>
In the documentation at ConvertFrom-GisPoint - MilestonePSTools Module , it says:
Milestone stores GPS coordinates as X,Y coordinates on a standard coordinate plane. For example, the coordinates 47.25726, -122.51608 are represented in Milestone as “POINT (-122.51608 47.25726)” where the latitude and longitude are reversed. An unset coordinate for a camera is represented as “POINT EMPTY”.
So based on what I’m seeing, the SOAP API is “POINT(lng, lat)”, which is correct. This makes me think there’s a bug in the AI Bridge.
Hi Ben,
Thanks for reporting this.
We will take a look in the following days and come back to you.
PS: We can ensure this hasn’t changed for v2.0.3 so it may be the behaviour since v1.0.0
Hi @bevans_vc ,
we’ve identified and patched the issue (thanks for reporting it).
It will be available on AI Bridge 2.0.4 (next week).
Hi @bevans_vc ,
We’ve released a new version of AI Bridge (2.0.4). It fixes this issue.
Thanks for reporting it :wink:
