Hi there,
I was wondering if there’s a feature I’ve missed somewhere in the documentation to get a snapshot of a camera at a certain time? This is a heavily used feature for us, and I see in the gRPC documentation, there is this:
message SnapshotRequest
// ID of stream to take snapshot from.
string stream_id = 1;
// Maximum width in pixels of snapshot image.
uint32 max_width = 2;
// Maximum height in pixels of snapshot image.
uint32 max_height = 3;
// Token by which to authorize access to snapshot; leave blank to use
// default authorization.
string token = 4;
There appears to be an equivalent in the GraphQL schema too. Neither appear to have the ability to specify a timestamp?
This was previously a pretty easy thing to do using the ImageServer API:
<?xml version="1.0" encoding="UTF-8"?>
<methodcall>
<methodname>connect</methodname>
<!-- Return as JPEG, rather than raw camera data -->
<alwaysstdjpeg>yes</alwaysstdjpeg>
</methodcall>
Then
<methodcall>
<requestid>1005</requestid>
<methodname>goto</methodname>
<time>1772593334416</time>
<keyframesonly>no</keyframesonly>
</methodcall>
And a JPEG at that time would be returned. Usually <100ms in my experience. Sometimes <30ms.
The only equivalent way in the AI Bridge I’ve found (so far) is to:
- Initiate a playback stream around the time I’d like the screenshot taken (PlaybackStream)
- Receive the raw camera frames (h264/hevc), going back to the nearest keyframe
- Decode these frames using another method and calculate which frame is the closest to what is desired
This seems incredibly manual and error prone, and time consuming (>600ms in most cases).
Is there another method that can be used? Or if not, is it a feature which would be considered in the future?
