AI Bridge to Milestone VMS: ONVIF Metadata Not Appearing on VMS Side, not even recieving it.
Hi @lisber
ping from RS host to AI-bridge works, as I have already added entry in hosts file, to have a healthy connection in the first place months ago.
Hi @lisber
anything else to check? Please let me know asap, after tomorrow, I’ll be coming back only on next week. Thank you for the help till now.
Hi @Oferap ,
From these tests today am quite sure there’s something odd with the VPS connection.
When a user subscribe to a metadata or video topic from MC and a VPS hardware gets created there should be an entry in the “devicehandling.log” almost immediately.
2026-01-19 15:46:25.456+01:00 [ 20] INFO - 2e5b3f31-cf79-456e-a191-9836a3ce7c46 VPS - ServiceParametersChanged - Configuration:
2026-01-19 15:46:25.456+01:00 [ 20] INFO - 2e5b3f31-cf79-456e-a191-9836a3ce7c46 VPS - DriverParametersChanged - Parameters: VPSNODES,``http://esvm-ft17-50:8787/processing-server/metadata/28a6bc9a-0833-46c6-958e-19da4ee6d9e5/sendonvif/onvif_analytics/57b796aa-18a2-42e7-ae46-117a87fba165/28dc44c3-079e-4c94-8ec9-60363451eb40
2026-01-19 15:46:25.456+01:00 [ 20] INFO - 2e5b3f31-cf79-456e-a191-9836a3ce7c46 VPS - SourceCameraChanged - Source:
2026-01-19 15:46:25.456+01:00 [ 74] INFO - f8faa3ee-8bdf-4dc7-98f2-c83ea247e126 StableFPS_T800 (localhost) - Camera 2 [sendonvif-onvif_analytics] - Metadata (onvif_analytics) Starting frame group media db consumer
VPS Driver comes built-in on RS:
Can you check the driver is in your installation ?
Could you:
1 - Restart the RS service ?
Using the Connectivity-Sample application
2 - Unsubscribe all the metadata topics from MC
3 - Subscribe to one metadata topic. Check the configuration properties, check the VPS url it must follow the format: VPSNODES,http://[AiBridgeHost]/processing-server/metadata/[guid]/[topic]/[format]/[guid]/[guid]
4 - Click on the button to ‘Start’ sending metadata.
5 - Check the ‘devicehandling.log’ located in the RS log folder.
Since the problem is pointing to VPS I would like to double-check the driver is there (as expected) and also that RS can or not make the VPS work … :frowning:
Hi @lisber
These are the new log entries in device hanlding log, when following your instructions.
34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 13:19:50.772+02:00 [ 334] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 13:32:51.197+02:00 [ 69] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 13:32:58.900+02:00 [ 213] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:09:33.893+02:00 [ 43] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Device communication stopped
2026-01-19 17:09:33.909+02:00 [ 380] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Stopping frame group media db consumer (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:09:33.909+02:00 [ 380] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Closing the write cursor in the the frame group media db consumer (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:09:33.948+02:00 [ 380] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Stopping the performance counters in the the frame group media db consumer (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:10:31.759+02:00 [ 4] INFO - ******************************* Starting logger *******************************
2026-01-19 17:10:36.835+02:00 [ 39] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Starting frame group media db consumer (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:10:36.835+02:00 [ 39] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Creating performance counter for device frame group media db consumer (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:10:39.745+02:00 [ 73] INFO - 34f244d6-bd88-4db1-b769-33590a87fdd5 FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1 Device communication established
Hi @lisber
I could see the drivers there in the folder.
Hi @lisber
Please see the single subscription, Where to look for url?
these are the aib logs tail as well
==> aibridge-broker/broker.log <==
-stream-subscriptions-topic voyager.topics.daim.vmsbridge.stream_subscriptions
2026-01-19T08:36:32Z Server starting …
2026-01-19T08:36:32Z Verifying existence of topics in kafka cluster …
2026-01-19T08:36:32Z Verifying existence of topics in kafka cluster succeeded
2026-01-19T08:36:32Z Creating new kafka producer …
2026-01-19T08:36:32Z Creating new kafka producer succeeded
2026-01-19T08:36:32Z Creating new kafka consumer for group ‘d8c732cd-ea9f-4442-9f9e-03c63f6e4889’ …
2026-01-19T08:36:32Z Creating new kafka consumer succeeded
2026-01-19T08:36:32Z Server started
==> aibridge-connector/connector.log <==
2026-01-19T15:11:48Z Synchronizing configuration with XProtect VMS (4f6b754e-2b43-4619-9b66-64e4e8bbe837)
2026-01-19T15:11:48Z - synchronizing (0%): query graph …
2026-01-19T15:11:48Z - synchronizing (0%): query vms …
2026-01-19T15:11:48Z - synchronizing (25%): query graph done
2026-01-19T15:11:48Z - synchronizing (50%): query vms done
2026-01-19T15:11:48Z - synchronizing (50%): updating endpoint …
2026-01-19T15:11:48Z - synchronizing (75%): updating endpoint done
2026-01-19T15:11:48Z - synchronizing (75%): update channel groups …
2026-01-19T15:11:48Z - synchronizing (100%): update channel groups done
2026-01-19T15:11:48Z Synchronizing configuration with XProtect VMS (4f6b754e-2b43-4619-9b66-64e4e8bbe837) succeeded
==> aibridge-health/health.log <==
-sparql-query-endpoint http://aibridge-fuseki:3030/repositories/voyager/query
-sparql-timeout-in-seconds 10
-tls-certificate-file certs/server.crt
-tls-enabled false
-tls-key-file certs/server.key
2026/01/19 08:36:32 Server starting …
2026/01/19 08:36:32 Verifying gateway graph …
2026/01/19 08:36:32 Verifying gateway graph succeeded
2026/01/19 08:36:32 Server started
==> aibridge-init/init.log <==
2026-01-19T08:36:32Z Publishing ontology ‘./iot.ttl’ succeeded
2026-01-19T08:36:32Z Publishing ontology ‘./core.ttl’ …
2026-01-19T08:36:32Z Publishing ontology ‘./core.ttl’ succeeded
2026-01-19T08:36:32Z Publishing ontology ‘./gateway.ttl’ …
2026-01-19T08:36:32Z Publishing ontology ‘./gateway.ttl’ succeeded
2026-01-19T08:36:32Z Publishing ontology ‘./vmsbridge.ttl’ …
2026-01-19T08:36:32Z Publishing ontology ‘./vmsbridge.ttl’ succeeded
2026-01-19T08:36:32Z Applying registration using input from ‘/root/bin/config/register.graphql’ …
2026-01-19T08:36:32Z Applying registration using input from ‘/root/bin/config/register.graphql’ failed (will retry in 5 seconds) : Post “http://aibridge-webservice:4000/api/bridge/graphql”: dial tcp 172.19.0.9:4000: connect: connection refused
2026-01-19T08:36:37Z Applying registration using input from ‘/root/bin/config/register.graphql’ …
==> aibridge-proxy/proxy.log <==
2026-01-19T08:36:32Z Creating new kafka consumer for group ‘daim.vmsbridge.proxy.event’ …
2026-01-19T08:36:35Z Event map initialized
empty
2026-01-19T08:36:35Z Event map empty; waiting for updated event map to arrive
2026-01-19T08:37:00Z Event map updated
event.28a6bc9a-0833-46c6-958e-19da4ee6d9e5.getsnapshot.analytics_event → [ http://milestone4 ]
event.28a6bc9a-0833-46c6-958e-19da4ee6d9e5.sendanalyticevents.analytics_event → [ http://milestone4 ]
==> aibridge-streaming/streaming.log <==
2026-01-19T08:36:32Z Verifying gateway graph …
2026-01-19T08:36:32Z Verifying gateway graph succeeded
2026-01-19T08:36:32Z Creating new kafka consumer for group ‘0aef2cae-cfca-4ce3-ade0-741a6d196bff’ …
==> aibridge-webservice/webservice.log <==
2026-01-19T15:11:19.558Z debug: Parsing request to extract GraphQL parameters
2026-01-19T15:11:19.559Z debug: Processing GraphQL Parameters
2026-01-19T15:11:19.566Z debug: Processing GraphQL Parameters done.
2026-01-19T15:11:19.568Z debug: Parsing request to extract GraphQL parameters
2026-01-19T15:11:19.568Z debug: Processing GraphQL Parameters
2026-01-19T15:11:19.574Z error: Response CreateTopics(key: 19, version: 3) {“timestamp”:“2026-01-19T15:11:19.574Z”,“logger”:“kafkajs”,“message”:“Response CreateTopics(key: 19, version: 3)”,“broker”:“aibridge-kafka-broker:29092”,“clientId”:“vmsbridge/webservice”,“error”:“Topic creation errors”,“correlationId”:7,“size”:924}
2026-01-19T15:11:20.158Z debug: Processing GraphQL Parameters done.
2026-01-19T15:12:22.003Z debug: Parsing request to extract GraphQL parameters
2026-01-19T15:12:22.004Z debug: Processing GraphQL Parameters
2026-01-19T15:12:22.008Z debug: Processing GraphQL Parameters done.
You will be able to see the url here:
Let me know if the steps mentioned above (including the restart of the RS) helped to see VPS traces in the ‘devicehandling.log’ file.
Hi @lisber
Yes I followed the steps as you mentioned.
this is the url: VPSNODES,http://server_46:8787/metadata/28a6bc9a-0833-46c6-958e-19da4ee6d9e5/sendonvif/onvif_analytics/34f244d6-bd88-4db1-b769-33590a87fdd5/28dc44c3-079e-4c94-8ec9-60363451eb40
Hi @lisber this devicehandling log after RS restart, I dont see any VPS related log entry!!
2026-01-19 17:17:42.909+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:17:49.766+02:00 [   245] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:55:30.618+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:55:38.841+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:56:14.897+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:56:31.840+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:56:35.900+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:56:58.841+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:57:10.896+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:57:20.722+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:57:36.169+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:57:43.085+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:58:34.248+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:58:46.088+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:58:47.247+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:58:56.088+02:00 [   215] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:59:47.528+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 17:59:56.370+02:00 [   192] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:02:57.447+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:03:05.333+02:00 [   118] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:04:54.888+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:05:02.743+02:00 [   125] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:07:48.063+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:07:55.378+02:00 [   213] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:09:58.899+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:10:06.705+02:00 [   104] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:10:33.847+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:10:42.698+02:00 [   103] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:14:19.045+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:14:27.822+02:00 [   252] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:14:52.978+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:15:07.827+02:00 [   252] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:16:13.290+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:16:21.102+02:00 [   135] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:18:43.541+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:18:51.346+02:00 [   104] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:20:13.777+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:20:20.587+02:00 [   166] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:20:25.780+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:20:33.587+02:00 [   166] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:23:00.814+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:23:08.665+02:00 [    99] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:23:32.857+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:23:40.665+02:00 [    99] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:25:24.977+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:25:34.786+02:00 [    90] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:26:02.981+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:26:10.788+02:00 [   100] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:28:40.266+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:28:48.071+02:00 [    89] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:28:51.296+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:28:59.068+02:00 [    89] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:30:33.980+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:30:41.794+02:00 [   227] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:31:21.819+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:31:29.786+02:00 [   227] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:35:37.432+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:35:47.381+02:00 [   247] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 18:57:34.953+02:00 [    73] WARNING    - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  Device communication error (NoDataException). Error: GetMediaDataBlock returned no data.
2026-01-19 18:57:35.176+02:00 [    73] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  Device communication established
2026-01-19 19:12:38.625+02:00 [    73] WARNING    - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  Device communication error (NoDataException). Error: GetMediaDataBlock returned no data.
2026-01-19 19:12:38.831+02:00 [    73] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  Device communication established
2026-01-19 19:19:42.505+02:00 [    73] WARNING    - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  Device communication error (NoDataException). Error: GetMediaDataBlock returned no data.
2026-01-19 19:19:42.673+02:00 [    73] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  Device communication established
2026-01-19 19:33:21.510+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:33:28.451+02:00 [   212] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:33:51.609+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:33:59.459+02:00 [   212] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:34:51.897+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:34:59.778+02:00 [   225] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:41:51.659+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:42:00.501+02:00 [   141] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:43:53.378+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:44:01.219+02:00 [   105] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:44:52.822+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:45:00.666+02:00 [   170] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:46:44.910+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:46:52.783+02:00 [   115] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:50:11.468+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:50:18.311+02:00 [   185] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:56:46.301+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 19:56:54.148+02:00 [   188] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:03:00.985+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:03:07.833+02:00 [   225] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:05:20.548+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:05:27.399+02:00 [   225] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:05:35.546+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:05:43.396+02:00 [   137] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:22:22.551+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:22:30.447+02:00 [   105] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:30:22.884+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:30:30.696+02:00 [   252] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:44:16.091+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:44:23.935+02:00 [   122] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:56:02.495+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 20:56:11.298+02:00 [   254] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 21:08:01.820+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 21:08:08.664+02:00 [   142] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 21:39:58.552+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 21:40:06.400+02:00 [    27] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 23:21:32.358+02:00 [    25] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=True (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
2026-01-19 23:21:40.160+02:00 [   128] INFO       - 34f244d6-bd88-4db1-b769-33590a87fdd5  FLIR Systems CF-6408-00-0A (10.5.1.64) - Camera 1  OnRecordingStateChanged, isRecordingRecords=False (table: 34f244d6-bd88-4db1-b769-33590a87fdd5)
Something that caught my attention when comparing the VPS endpoint is:
Your endpoint:
Your VPS is lacking the ‘/processing-server/‘ this value is set by the MC Plugin based on the .env value ‘EXTERNAL_ROOT_PATH‘ in our compose-files we are always setting this value to ‘/processing-server/‘ have you removed its content ?
Could you please try:
1 - Unsubscribing again from the metadata topic on MC
2 - After unsubscribing the VPS hardware will be set to ‘disabled’, go and remove/delete it:
3 - Stop the AI Bridge
4 - Leave the ‘EXTERNAL_ROOT_PATH‘ as it is from our delivered compose-files. I.e. with
EXTERNAL_ROOT_PATH=“/processing-server”
5 - Start the AI Bridge again
6 - Close and Start MC application
7 - Subscribe to the metadata topic
8 - Check the VPS url has ‘/processing-server’/’ on its path
9 - Check the ‘devicehandling.log’ file
An entry containing VPS keyword should appear in the logs file.
Hi @lisber
I removed it following a insstruction from a previous message, never added it back.
Hi @lisber
I have added as you said, and it look like
But no progress on metadata or entry in device handling log.
Anyway I wll be back on next week alone, thanks for the help so far, looking forward to solve this.
Hi there,
Today I had a talk with a colleague who works on the Recording Server.
He mentioned something important. Looking at your VPS hardware:
The icon shows a blue square status, that means that the device is stopped (it hasn’t started) and that explains why there’s no entry in the devicehandling.log
The hardware I get created on my machine looks like this:
The icon shows a a green triangle status. Meaning the device has started.
My colleague told me probably there must be an error message in the RS main log RecorderEngine.log (at C:\ProgramData\Milestone\XProtect Recording Server\Logs\).
To find the VPS metadata ID that’s being added when you subscribe to a metadata topic you can do the following:
1 - While keeping the control key pressed, click on the VPS metadata device:
The ID that MC shows is the ID of the VPS metadata device that was created and we should use it in the RS logs to find specific errors related to this.
I hope this can help us understand why the VPS device is not starting (green triangle status on MC).
Hi @lisber
I am back, and I will reply after checking, Thanks
Hi @lisber
there is no entry in the above mentioned log as well.
Hi @Oferap ,
That’s weird :frowning: . Would you mind sharing your RS logs (the whole folder zipped) also which is the VPS ID.
When the device start there was suppose to be an error in the logs :frowning: ….
Hi @lisber
ID and primary table = ae3f984d-0896-4eea-a4c2-b202bbf1bf3d
Edge table = 6617529c-e3d7-4595-8467-dc798cc0cf9f
Please find the logs
Hi @Oferap ,
Looking at the RS logs I see the following error multiple times (VPS - related):
HardwareDriver.log
2026-01-19 17:10:36.231+02:00 [    40] ERROR      - ce0a391e-56c5-4e90-bf4c-c870a1ee5484  http://milestone4/  VPSHardwareDriver.Start(), ex=Failed to login to Management Server! + Uri=http://milestone4/
2026-01-19 17:10:36.231+02:00 [    42] ERROR      - 28cb8180-3e9a-443d-85de-5dba20d85830  http://milestone4/  VPSHardwareDriver.Start(), ex=Failed to login to Management Server! + Uri=http://milestone4/
2026-01-19 17:10:36.231+02:00 [    34] ERROR      - 37c66350-7242-422e-ae09-9868b06dd837  http://milestone4/  VPSHardwareDriver.Start(), ex=Failed to login to Management Server! + Uri=http://milestone4/
RecorderEngine.log
2025-09-03 16:05:18.458+03:00 [    53] ERROR      - Start hardware failed, HardwareId: f0ba2567-1b3b-4ca6-b8a9-069879703ebf, exception:
VideoOS.Platform.MIPException: Failed to login to Management Server!
   at VideoOS.IO.Drivers.VpsHardwareDriver.Start()
   at VideoOS.Recorder.ObjectModel.Hardware.DriverStart()
   at VideoOS.Recorder.ObjectModel.Hardware.Start()
   at VideoOS.Recorder.UpdateHardwareCommandHandler.StartHardware(UpdateHardwareCommand command, IResponseSink responseSink, ICallContextInfo callContextInfo, IHardware hardware)
2025-09-03 16:05:18.460+03:00 [    53] WARNING    - CommandHandler unhandled exception, token=1a726104-0f39-465a-9924-9f436461706e, type=VideoOS.Recorder.UpdateHardwareCommand, exception=VideoOS.Platform.MIPException: Failed to login to Management Server!
   at VideoOS.Recorder.UpdateHardwareCommandHandler.UpdateHardwareState(UpdateHardwareCommand command, IResponseSink responseSink, ICallContextInfo callContextInfo)
   at VideoOS.Recorder.UpdateHardwareCommandHandler.Execute(CommandBase command, Object state, IResponseSink responseSink)
   at VideoOS.Common.Integration.Command.ThreadPoolCommandExecutor.<>c__DisplayClass5_0.<Process>b__0()
Based only on these logs (RS) is not conclusive the reason.
I will kindly ask you to zip the entire folder: C:\ProgramData\Milestone (on your VMS installation)
To see if we can correlate (based on the timestamp) what can be the reason of this connection failure.
Hi @lisber
Sure, I will zip it and send it.
