Confirmed that I’m using v1.7.2. A diff of the Helm chart I’m using and a freshly-untarred version of the Helm chart from NGC shows they’re identical except for config/register.graphql and values.yaml, which makes sense. So I’m not really sure what else I can do to troubleshoot here.
Yes, I understand it’s working for *you*. I need help in determining why it isn’t working for *me*. This is happening on two separate machines using the same Helm chart from NGC, so while I appreciate it works fine for you, I could really use a hand in determining why it isn’t working for me.
I’ll try asking again: Is there any info I can post on here or any commands I can run to generate such info that might give you/others some insight? Or something I can compare? I just need help troubleshooting this, please and thank you.
Thanks for your reply. I’d like to ask you the logs produced on a new run of AI Bridge.
They are located in your Linux box running K8 under /var/log/{{ .Release.Name }}/.
The {{ .Release.Name }} value is set when you install the helm charts as in:
helm install releaseName . -n namespace
Please, to move forward with these efforts properly, I’d like to kindly ask you, as well, to create a Milestone Support case on behalf of Resorts World.
After checking the logs, we found out that your setup is pointing to an old version of XProtect, namely XProtect Corporate 2021 R2 Test (21.2a build: 1877).
Despite it gets connected and syncs, there are dependencies that we cannot asure are available on that version, thus, I would like to kindly request you to test your integration with a newer version of XProtect.
As a reminder, AI Bridge supports an XProtect version higher that 22.1 (22.1 and 22.2 need to be patched and patches can be found on NGC).
I see. I’ve been using AI Bridge since it was in beta and the requirement then was a patched 2021 R2, and it’s worked up until 1.7.2. I didn’t know that had changed.
I will see about updating my local version when I have a chance as I can’t afford to do so right now (we’re in the middle of some development that requires a working XProtect). I’ll also do my best to check with our client’s version.
